Tilt Camera problem
hey guys, hope somebody can help.
have don the latest firmware update v1.4.0010. After a few problems the update txt file says succeed.(also while updating the camera was vibrating for a while)
But now when I start the phantom the camera makes some strange movements shaking and then tilt down.
Whatever I try nothing helps, recalibrate the gimball, reset setting, + or - in the settings not working.
I think there is something wrong with the firmware. Tried again but txt file says same or older firmware, not possible to reinstall.
I have video and all the rest is working.
plse what can I do, is there a possibility to reinstall the fw or so ?
Can you post the screen shot of the firmware screen??
I'm not sure how its related but I've heard that the firmware makes screws come loose.
Look at the gimbal board and the flex cable. Look where the flex cable starts from the gimbal board. On the opposite side is a hidden hex grub screw. Tighten this to the flat side of the D shaft.
jrl
