Thought I had a fly away - RTC
Discussion in 'Phantom 2 Discussion' started by teslar, Nov 29, 2015.
  1. teslar
    East Lothian UK
    Yikes! I was out testing Naza mode and flew out about 750M to some trees on the horizon. As I was turning for home my video feed was breaking up so I decided to use the home lock feature. That's when the phantom headed for China and I had that sinking feeling ............:
    After some switch flicking I realised I had control but it was wild and not helped by strong wind higher up about 100 meters. I really struggled to get it home then tried home lock again only for it to go wild again. After a real struggle in the wind I managed a fairly bumpy landing on grass that ended in a garden hedge but fortunately no damage was done. On closer inspection I spotted the right hand switch was in ATTI mode so I must have flicked that accidentally and I guess that's what stopped GPS lock on home, lack of hovering and drifting on the high wind
    Now my heart rate has returned to normal I've ordered the Rave Aerial mount to replace the one I've been using as it obscures my vision and I think contributed to the problem in that I cannot see the switches and it interferes with the controls
    Hopefully that's a lesson learned and fortunately no damage done
    In the plus side I guess that was my first ATTI flight and landing. Not bad for my third flight :)
    Sadly no video footage to remind me. That was another bad idea of mine. I changed the GoPro to one button use and I'm not getting along with that it seems I started and stopped the video recording before it took off :(
  2. jason
    Commerce Twp,MI
    I am just the opposite and find the one button very useful. When using two buttons I sometimes forget to start the recording or like you turn it on then off not noticing that it isn't recording. I agree that mount is a pain as it not only blocks your view of the switches plus it's unstable.
  3. Gary E
    Medford, Oregon
    Yes, that mount puts the monitor way too close for me. What keeps the Rave mount from pivoting forward on the bottom metal bar?
  4. jason
    Commerce Twp,MI
    The rave mount slips over antenna and snaps onto the bottom bar. There is one on Shapeways that goes on the same way but the monitor base is adjustable.
    DJI Phantom - FPV Monitor Mount by questpact on Shapeways
  5. Gary E
    Medford, Oregon
    I see from the image that it slips over the antenna, but what keeps it from pivoting forward and then down with the weight of the monitor on it? And if there is a windsurfer antenna booster on the RC antenna (it also - friction fit - slides down over the antenna mount), which I have, then both of those styles of monitor mount cannot be used.
    I use the carbon fiber vertical brackets that bolt to the RC bars with the carbon fiber top plate on them to mount the monitor.
  6. jason
    Commerce Twp,MI
    I use the same monitor mount.
    Gary E likes this.
  7. jason
    Commerce Twp,MI
    On the other leg of the mount I have a DVR recorder to record video/telemetry of each flight. You can call me cheap but I will not put anything on my P2 that require a monthly fees.
  8. antares
    Philippines
    Hi Jason,
    the cloverleaf antenna has a minimum reception at 0 deg and 180 deg from main axis. By mounting it the way you show on your pic it seems to point to the direction of the P2 with it's signal minimum. Only helical or flat antennae should point to the tx, while a cloverleaf shall be held vertically... Just an idea.
  9. jason
    Commerce Twp,MI
    All the signal from a cloverleaf antenna come from the sides and very little from the top. That is old photo on the monitor I use a RX cloverleaf and a 13dbi SpiroNet Patch antenna. While on the P2 there is RX (not a TX) cloverleaf attach to immersion 600mw TX.and I get very little video dropouts.
    This video is excellent if you haven't seen it before.
  10. antares
    Philippines
    Nice video! Hovever, a clover-leaf antenna is omnidirectional in the horizontal plane only. In the vertical plane, it shows two minimums at 0 deg and 180 deg, see here. With a diversity receiver, probably you will not run into problems.
  11. jason
    Commerce Twp,MI
    With the setup I am using I have no problems whatsoever..
  12. teslar
    East Lothian UK
    I mounted mines vertically as I would only fly over head when I'm landing or taking off and even then I'm well within signal range. So no issues
Similar Threads - Thought fly away Forum Date
I thought I was having a flyaway, but I wasn't... General Discussion Jun 1, 2014
Thought I had a flyaway, but then... General Discussion Aug 22, 2013
Thoughts on back roads and flying Rules and Regulations May 14, 2017
And you thought attitude flying was hard... Off Topic May 15, 2015
Night time flying and after thoughts Phantom 2 Vision + Discussion Jun 30, 2014
