This happened to anyone?
Was flicking the S1 switch up and down and it just came off in my hand?
Anyone fixed anything similar? Or am i looking at a whole new remote?
Just replace the toggle switch !
Remote comes apart easy and its about a 5 dollar switch. Just solder the wires.
May as well do both while in there.
Low quality parts on the OEM Tx.
slothead said:
Huh? (1) What's a Compass app and (2) what does it have to do with using S1?
Probably referring to the Vision app on the phone. There's a function in there to start the calibration procedure without using the switch.
Any sites in the UK where i can order this? Neither of those places deliver to me :-(
Thanks for all your help guys!
Its a common switch. SPST center off.
The voltage and current capacity does not matter. Any electronics shop will have it.
Here you go 99p in UK
http://www.maplin.co.uk/p/sub-miniature ... dpdt-fh06g
Not sure that's correct.
Doesn't the description indicate it's momentary (i.e. non-locking) in one of the two end positions?
You want it to remain in either of the three positions upon selection.
You might consider a DPDT on-off-on switch. You would have redundant contacts. It would require just a little dremeling on the inside to fit the wider switch. Replaced both on mine, worked fine until X1 failed then fixed that with a Futaba.
Can anyone help me out with a UK link for something that work. I do not have an electronics background at all, but i can solder it on.
Just need to buy the right part.
Thanks for your help....
shimuafeni fredrik
