Theoretical Question
Discussion in 'Phantom 2 Vision Discussion' started by NoFlyAways, Feb 3, 2014.
  1. NoFlyAways
    Hello all. So knowing that we can turn the P2V rotors on and off by (left stick [bottom right] & right stick [bottom left]) ...
    Is it possible to send the P2V up really high like 1000 feet... cut the motor and turn it back on when it drops to 500 feet? Might give a cool camera angle of a free fall.
  2. amrflyingdude
    I think you can indeed cutoff the motors in mid air, now that is very risky as the sensors may not be able to recover from such unusual attitude.
  3. Byroman
    Libby, Montana
    Since I'm total chicken... I'll let someone else try this maneuver. Just PLEASE post the video! :shock:
    lol
  4. Scottrod
    Fleetwood, PA
    +1! Balls of steel to try it! I would be scared the command to restart the motors wouldn't get received in time to recover.
  5. dkatz42
    New Mexico, USA
    The various falling-from-the-sky videos seem to indicate a propensity for stabilizing feet-down, albeit with some spin, with the props windmilling like crazy. Bodes reasonably well, but no, I'm not going to try it. ;)
  6. LeoS
    You can see it in your mind, how the propellers on the Phantom stops.. loses momentum and falls down wildly.. and after a brief second, restarts and stabilise itself on command, and hover to the astonishment of many.
    This question will slowly chip away at your soul and starts an ever growing itch until you do the test and film it...
  7. neil64
    Midwest USA
    Many of us have already discussed this in another thread. Of course you could do it, and it would most likely be fine as long as you had enough room for the Phantom to correct itself.
    viewtopic.php?f=4&t=7498
  8. Drone-Outlaw
    United States,Houston, Tx
    Have watched a video of a quadcopter that had its engines cut out @ 2000'. At 1st looked very unsteady & wobbly for what looked to be a few hundred feet. The craft had a camera that also recorded sound, you could hear the engines whining as it autorotated back to the ground. It became perfectly stable as soon as you heard the engines whine and props chopping through the air. You see the unit bounce as it hits the ground, but not in a catastrophic way.
    I don't think the pilot cut the motors on purpose, but it was nice to see the AR work & the craft make a landing that might have much less damage than if it just dropped out of the sky.
    Moose
  9. jengo
    San Francisco, CA
    If it tips over and you give it power ... you are going to have a nice quick landing :p I doubt it would do very well at righting it self back up from upside down.
  10. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Try a fast decent once (without killing motors) and see the results. I think that'll answer your "theoretical question"
  11. iResq
    Annapolis, Maryland
    In practice this is really a dumb idea. How would you even begin to defend yourself should something go wrong?
  12. gpauk
    Aberdeenshire, Scotland
    Well if you had a lot of friends holding a big sheet out to catch it...........
  13. neil64
    Midwest USA
    Anyone who has let their battery power fall too far while in the air knows what happens when the Phantom(2) falls. It will recover just fine from being upside down, as long as it has battery power and enough time to recover before smashing into something.
    I wouldn't think there is any defense for that. It simply should not be attempted unless one is willing to accept responsibility and accept the risks of property damage, etc.
    I may go get some footage of this experiment as soon as the weather clears up here, but that might be a while. If anyone else does this, make sure you get decent footage from the air as well as on the ground.
Similar Threads - Theoretical Question Forum Date
Home Point Theoretical question Phantom 2 Discussion Nov 15, 2014
There I was...theoretically Pro/Adv Discussion Apr 6, 2017
Theoretical fall/crash scenario. General Discussion Sep 3, 2016
Location Question Rules and Regulations Saturday at 7:10 PM
Question about flight outside of national forest Rules and Regulations Saturday at 12:39 AM
