The 4 motors stoped and is craseh on the ground
Discussion in 'Phantom 1 Help' started by Gasff, Jul 30, 2013.
  1. Gasff
    Portugal
    Hi
    I need help, i have a DJI Phantom that now have a problem, it hapened to me 2 times, i was fliyng in gps mode and when i was going donw all the motors stoped and the DJI Phantom Craseh on the ground ;
    this the vídeo from that;
    http://www.youtube.com/watch?v=iy-3HoVDKho
    I sended to the store and they said that was EMU calibration, they calibrate and sended back to me, when i made the first flying test afther that i was at 3 meters from the ground ( static) with a litle bit o aceleration on the transmiter and it happened again, all the motors stoped and the DJI Phantom crashed again on the groun.
    What could be the problem ?
  2. gardenroute
    Czech Rep.
    Normally, in-flight motors stop perhaps only in Manual mode (and maybe not even that). you do not happen to have selected him to switch flight modes?
  3. martcerv
    Did you make any changes to the battery voltage levels? I think if you disable this or set the levels too and voltage hits 3.2v per cell under load the ESC's will shut down the motors and this could cause it to shut down and come down like a gliding multicopter. Well they glides as well as a rock so make sure you never get voltage so low that the motors shut down.
  4. boat chaser
    Fremantle, Western Australia
    Looked like you were in manual mode. The engines only stopped briefly, then started again around impact.
  5. boat chaser
    Just found out you were in gps mode on the youtube page. That is scary, nice crash though.
  6. PhantomHubert
    Wich firmware? I believe on 3.1 motors shut of when throttle is below 40%. DJI did bring out 3.12 shortly after that.
  7. boat chaser
    I don't think the firmware was your problem. If you were in gps mode that is a very abnormal behaviour. I can descend with throttle on 0 and my motors have never shut off. Hope you find a solution.
  8. boat chaser
    btw latest firmware is 3.14 (gimbal related)
  9. Gasff
    Portugal
    I had Contacted DJI Inovations Europe and , they said that never hapened to others , i will send him again to the seller store and they will test and and maybe send to the Eurpean centre.
    Tank you all for the help, i will give you news as soon .
Similar Threads - motors stoped craseh Forum Date
rear motors stop on takeoff Phantom 4 Pro Help Jan 13, 2018
Phantom 3 vibration after removing motors Pro/Adv Discussion Jan 11, 2018
my motors Phantom 4 Pro Help Jan 8, 2018
You were worrying about getting motors wet.... General Discussion Jan 7, 2018
Standard One of 4 motors doesn't work right out of box Phantom 3 Help Dec 28, 2017
