I just finished a clip that discusses a few "single points of failure" on most drones that can be avoided with a little prep.
IMO, calibrating the compass and IMU is really the fastest way to lose your Phantom.Interesting...I was surprised that nothing was mentioned about calibration. IMO, not calibrating the compass and IMU, is really the fastest way to lose your Phantom.
Another way to cut down on time is to not spend so much time talking about the obvious. Everyone knows that the battery powers all of the systems, no need to describe each thing the battery powers, we know. I didn't make it through to the end either.Good video and good luck with your endeavors. I watched most of it as well as some of your other posted videos. My advice for what its worth, this should be a 3-4 minute video, not 20 minutes. You discussed a lot of topics, put those into other "short" videos, keep on point. This is the internet, we want our info like crack, 20 minutes will not work to tell people to check their props, look for dirt and know your surroundings. For example, you start off the video talking about all the systems DJI has put in place to avoid crashing. This, should easily be its own separate (5 minute) video with its own appropriate title as search criteria: "crash avoidance systems in the phantom 4". I've also seen you caveat your video's on how "you really like DJI and you're not bashing them", separate video! Compare what you like about DJI to other drone manufacturers and do it as separate content. Don't waste time on each and every video, caveating that fact. Of course, if you're just doing this as a hobby, then so be it, don't turn it into a job and dont listen to me Everything seems professional and high quality and easy to understand, keep it up and I look forward to seeing more! And now, for the TLDR which is so fitting
TLDR: His video is is great but too long, goes beyond video topic, does not take advantage of separate, categorized content for seo purposes, suggest he stick to point and length low.
It's not giving him a hard time, just friendly advice. I'm actually subscribed to his channel and have gotten a lot good info from his videos. I even purchased a Microraptor hard case and backpack based on his review. This one was too long for the amount of content, though.Stop giving the guy so much hard time, is not for you pros, it's for the not so pros!!!
Good job buddy
Good Job Rick, Thanks so much for the advice and will look forward to hearing more from you.I just finished a clip that discusses a few "single points of failure" on most drones that can be avoided with a little prep.
