Text overlap in Mini IOSD
Discussion in 'Phantom 2 Help' started by tritonite, Aug 4, 2014.
  1. tritonite
    Hello,
    I installed a mini IOSD and transmitter last week. I am using a Black Pearl as a monitor and I can see the text but it seems to be overlapping in the screen. Is that normal ?
    Photo attached of how it looks.
    The video seems to have a bit of interference. I have ordered the 600mw transmitter and polar antennas to see if that fixes it..
    Thanks !
  2. OI Photography
    Clarksville, TN
    The data at the top of the screen in that black bar is the OSD on your gopro camera (shows status, cam batt level, etc), the rest of the data is from the Phantom's iOSD mini, some of which overlaps the gopro OSD. I haven't seen any way to keep the two OSD's from overlapping, and like many I've just disabled the gopro's OSD via the camera's menu to get around this.
  3. UrAwFuL
    Los Angeles, CA
    I get the same problem. You can "easily" disable it via in-camera settings or if you have a LCD backpack for it that you can attach before mounting into Phantom. I wished there was an option for it via Phone app.
    Also, there is a setting that can be changed via iOSD assistant software to move the HUD.. but the last time I tried didn't really make a difference (I think it was just a toggle from square to rectangle view).
    Manual.
  4. freefall101
    Just turn off the GoPro OSD, there's very little practical need for it and it looks much tidier without the two together.
  5. 750r
    Pa, USA
    The thing I like about having the GPB OSD on for is knowing the GPB is recording (red) & knowing the wifi is off . I have the osd off on my GPB+ when I use it I fill like something is missing . :D
  6. UrAwFuL
    Los Angeles, CA
    Yep, I totally agree with that. Twice in a row I'm mid-air and realize I forgot to hit the record button once I look on my monitor.
  7. tritonite
    Thanks, OSD turned off, much clearer now :)
Similar Threads - Text overlap Mini Forum Date
On screen text display Photos and Video Jul 22, 2017
I sent a friend a text and told him to go out and look for me in the sky. Photos and Video May 30, 2017
Learning 3D Animated Text and Objects on Walls Photos and Video May 4, 2017
Text or phone call when flying Standard/4k Discussion Feb 19, 2017
Go 4 App -- tiny text Phantom 4 Pro Discussion Dec 2, 2016
