Uhm very interesting....
My thoughts:-
I think in order to get enough power up a 150' cable and the cable still be light enough for the Drone to support, would require the use of inverters and an AC power source.
The
P4P consumes approx 120 -130 watts to stay in the air, drawing approx 7 - 9 amps of continuous power @ around 15.2 Vdc from the battery.
Using a higher AC voltage say 80 - 100 Vac the current carried by the cable could be reduced to a couple of amps, and playing around with the Voltage and the Frequency could allow a further reduction in current, thus a smaller cable required.
Then instead of a heavy Lithium battery you would use a custom made Inverter housed in the Drone to supply the power instead of the battery.
It obviously works because such tethers are commercially available, so needs someone with enough Geek power to work it all out....
Waylander
