performs and flying time mm maybe vibrations but was good performance and other then that is same then standard props[emoji848]How do you plan to test?
yes they are!Are they DJI OEM props?
I tried clones and had to throw them in the garbage, as the drone eventually went nuts, twitching and wouldn't hold a hover.
in some how I do like them , in my opinion they are more stable then the standard but I feel they sound more and I guess they will be easy to brake for any stupid move but after all I will keep use it anyway!I've been trying out the DJI carbon fiber props. I've gotta say, I don't like them. The P3 seems much more jittery with them on...probably because they're substantially stiffer than the stock ones. I'm switching back.
I also had heard they were stiffer and made more noise which would not bother me if I liked them.
Any vibrations?[/QUOTE no vibration at all! its just perfect like I say and if u don't bother the sound take the chance, by the way I will make it some more testing because I even can see any drifting like the standard give me even wen I have the V2 professional
Different history for me! I will keep itI have the carbon once and replaced them back with the original once. Flight didn't feel stable enough, too noisy and too stiff. Also make sure you balance them. They were quite a bit off. And yes they were from DJI
Sent from my SAMSUNG-SM-N910A using Tapatalk
