Terrible range on FPV Set Up - Please Help
d4ddyo said:
Does the antenna have to be pointed perpendicular to the transmission like a radar dish?
Roughly... it seems pretty good in most orientations but face on works best. If you are using it with a diversity receiver it's interesting to see when the patch overrides the other (in my case a Helical) antenna and I find that the patch does about 70% of the work, the helical only really kicks in once I send my P2 into the distance.....
poostik said:
GhostMaster said:
poostik said:
Will different channels make a difference? I thought they were just there so you could differentiate from others if you were flying at the same time.
I know I don't have the best FPV system but mine seems to be cutting out way more than a friend of mine who has the same one.
I get static even when it's 50ft away :-/
Yes makes difference..
Output power: http://i.imgur.com/JAZiz9L.jpg
So does the higher number = better/stronger signal?
Yes it means.
mactechnic
