- Joined
- Mar 17, 2014
- Messages
- 137
- Reaction score
- 0
So my set up is a P2, with Zenmuse H3-2D, Mini iOSD, Boscam FPV 5.8G 400mW AV Transmitter Module TS353 from Banggood, 5.8G 3 Leaves Omnidirectional Gain Antenna For Transmitter from Banggood and FPV 5.8G 7 Inch LCD Monitor With Built-in Battery & 5DB Antenna also from Banggood.
With this setup (first time trying it last night) I went to 100m height directly above me, as well as 100m distance at 30m height and by that point the video was breaking up to the point it was not legible on the monitor.
I have the cloverleaf antenna on the video TX, and i tried it at 90 degrees to the horizontal, 45 degrees and fully horizontal.
I also tried the receiver antenna vertical, perpendicular to the P2 position and fully horizontal but nothing seemed to make much difference.
Any thoughts what could be obviously wrong? Should I try the stock antenna on the video TX, or do I need cloverleaf on both ends to see any benefit?
