Is it possible to have the DJI Phantom 4 Pro in Terrain Mode while taking a grid survey? I would like to be able to perform a grid survey, having the drone survey a grid (taking photos at selected intervals), while maintaining a constant height of ~2-3 meters above the ground. This requires being able to ascend or descend according to the terrain. However, I see that the terrain follow mode only allows it to ascend, but that you can pull the down stick while going downhill and it will descent do your min altitude. Is this type of behavior possible while conducting a grid survey? This is for a research project that requires images taken from a consisten height of 2-3 off the ground over a grid area with possible small hills/dips. Is it possible?
Thank you!
Thank you!
