ElGuano said:A stock phantom should run for 10-12 minutes without a gimbal or camera attached. If you are getting 8, I assume you are flying with the gopro in the waterproof case? That is a 180g combo. The tarot weighs 180g on its own, not including the camera. So you would be looking at about 6-7 min flight times with the gimbal installed. Depending on how aggressively you set your low voltage alarm, you might be able to eke out 30 seconds to a minute more.
