Tarot 2d Gimbal Shake ????
Discussion in 'Phantom 2 Help' started by fessette48, Aug 4, 2014.
  1. fessette48
    I am having problems with my tarot 2d gimbal as of right now. I have looked around and have found no solution. I have tried to tighten down the set screw on the back of the gimbal with no luck. it works fine at times but when i go to use the tilt control it starts to act up.. however if it is facing all the way down (filming the ground) it seems to work fine and the footage is smooth as it acts normal.. as soon as i rotate the camera so it is filming straight out it seems to shake and the footage is terrible.
    this just started happening it has worked fine in the past. another thing i noticed is when it was actually filming good footage with the gimbal not shaking the tilt control would not work and i was unable to film the ground.
    gimbal facing the ground = good footage no shake
    gimbal facing straight out = shaky footage
    gimbal facing straight out on another flight 20mins later = good footage no tilt control
  2. CarlJ
    Peru, Indiana
    Calibrate X1 in the Asst Software.
    [​IMG]
  3. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    fessette48 - Please post your topics in the correct location. I have moved this one from 'News' for you.
Similar Threads - Tarot Gimbal Shake Forum Date
Tarot gimbal shakes when i connect gopro to fatshark Phantom 1 Discussion Sep 10, 2014
Tarot gimbal shakes when I connect gopro to fatshark General Discussion Sep 10, 2014
Home made gimbal using part out of a tarot 680 pro Pro/Adv Discussion Oct 23, 2015
Tarot Gimbal Problems. FPV (First Person View) Jul 16, 2015
Problems with pitch using Tarot 2D Gimbal Phantom 1 Discussion Apr 13, 2015
