Taking apart the cover
Discussion in 'Phantom 2 Vision + Discussion' started by worldsoutro, Nov 21, 2014.
  1. worldsoutro
    Hello all,
    Just to confirm I need a screwdriver and a Hex driver?
  2. malibusteve70
    yep, very small screwdriver. Careful they strip really easy
  3. Meta4
    Meta4 Moderator
    Staff Member
  4. Prylar Bek
    Where is this screwdriver hiding? Didn't get one
  5. Mopar Bob
    Connecticut, USA
    You need a tiny Philips (like for fixing eyeglasses) and a 2mm Allen. Make sure you don't use magnetized versions of the tools or you could throw off your compass. When you are done, shitcan the Philips screws and go to the hardware store and by standard flat heads. Can't remember the size, but the HW clerk will help. Philips are the worse design known to mankind.
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
  7. Meta4
    Meta4 Moderator
    Staff Member
    Have DJI dropped it? My P2v & P2+ both came with a nifty phillips/flat screwdriver just the right size.
  8. AHill
    A screwdriver came with my Vision but there was none with my Vision Plus.
  9. AndyA
    Gothenburg, Sweden
    Re: Sv: Taking apart the cover
    M3 8mm philips head fits perfect.
  10. justin00
    Australia
    #N-0 Philips for the 4 screws (1 on the end of each arm)
    and 2mm hex for the other 12... Helps if it has along bit to the get the 4 screws closest to the middle (1 on each arm again)
  11. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The screws on the very end of the arms are actually 00 Phillips.
  12. RedBaron
    I find that a 5/64 hex screw driver is a little better than a 2mm. A 0 or 00 phillips should work well for the others. All these screw's have loctite on them so they may need a little pressure to remove!
Similar Threads - Taking apart cover Forum Date
Taking off from my apartment, then over to the paintball field. Standard Mar 18, 2017
Taking pictures of a field - how far apart Control (Go, Litchi, etc..) Mar 16, 2017
Honestly a little overwhelmed with taking apart P3 advance Pro/Adv Discussion Feb 12, 2017
Taking apart the p4p? Phantom 4 Pro Discussion Dec 6, 2016
taking apart a smart battery Phantom 2 Vision + Help Jun 14, 2015
