Take off issue...
Discussion in 'Phantom 2 Vision + Discussion' started by Phantom_Menace66, Jun 29, 2014.
  1. Phantom_Menace66
    Perth, Western Australia
    Hey everyone, ok had my P2V+ for few months now and clocked up dozens of flights. I have used solid CF non self-tightening props pretty much since I got the thing and never had an issue taking off. Of course you have to give the throttle a bit of a stab or it might tip over. However.... The last few flights I've noticed it doesn't matter how hard I shove that left stick, the nose of the Phantom lifts before the tail and the props just miss the ground and it lurches backward about 2ft. Soon as it is in the air though, it's perfect. Hovers in one spot with almost no drift at all and flies beautifully.
    So I tried it with the genuine DJI plastic props and the launch was even more scary, the rear props mowed the grass a couple of times! I landed and took off about a dozen times, same tilting. Tried it on grass, bitumen and concrete. same thing.
    It's really annoying as it used to go straight up. Any ideas as to what is causing it or how to resolve the problem?
  2. 4wd
    4wd
    North York Moors
    I had two unexpected tipovers on take-off one evening, and put it down to springy short grass at the time.
    I set it on the case, which gave more clearance, and it flew fine.
    At home did a full IMU although it said not needed - seemed much better next time.
    It had been on its side in a backpack for an hour before -I wondered if that bothered it.
  3. amkorp
    Toronto, Canada
    Do an IMU (full) calibration, even if the software says you don't need to. You'll be fine after that.
  4. Mori55
    NJ-USA
    Why even use the carbon props ? What's wrong with the stock ones ?
  5. Joeg1937
    Estero, FL
    All the more reason to use prop guards, call me what you want but at least my props never get damaged......
  6. N017RW
    Palm Beach Co.- FL
    I have always applied full throttle at take off.
    No tilts, tips, or other mishaps.
    (never used prop guards)
  7. BigTulsa
    Tulsa, OK
    If you fly properly you should never need prop guards. Prop guards to me equal too much of a chance of getting stuck in VRS.
  8. Joeg1937
    Estero, FL
    And what do you consider " flying properly" ...I fly almost every day and fly by the book, so what else is there ?
  9. BigTulsa
    Tulsa, OK
    Wouldn't consider flying with guards. Too easy to get stuck in VRS.
    I would consider "flying properly" as not flying over people, not trying to hot dog through trees and neighborhoods and the like
    But then again, that's just me.
  10. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Do an Advanced IMU calibration on a perfectly level surface, then do a stick calibration, then compass calibration.
  11. Phantom_Menace66
    Oh brother!? I didn't mean to start a debate over prop guards... Sheesh!
    Have done the advance IMU cal etc and it seems to have resolved the issue.
    Thanks everyone for the advice, most appreciated... :D
  12. Phantom_Menace66
    Just my personal preference & in my opinion the Phantom is more responsive & hovers much smoother. I have also noticed that the plastic props are so soft, that when I fly in temperatures over 30deg C, the props become very soft & rubbery near the tips causing a loss in lift, whereas the CF props don't appear to be effected by the heat/cold & do not flex at all. Again, these are only my personal opinions brought about through trying different props in different conditions.
    I also don't like the idea of self-tightening props & although very unlikely, I have read several reports of props coming off in flight. I wouldn't be keen to drive my car at speed knowing I had self-tightening wheel nuts! :lol:
Similar Threads - off issue Forum Date
One motor spinning slow before take off - is this issue? Phantom 2 Vision + Discussion Feb 24, 2017
UK Police Guidance on Drones - Document issued to Officers Rules and Regulations Feb 4, 2017
Weird Power on/off issues. Remote & P3P. Pro/Adv Discussion Oct 23, 2016
P3 proff live feed issues, how good can it get ? Pro/Adv Discussion Sep 5, 2016
DJI Official Forum - Easier to ban than resolve service issues? Off Topic Jul 26, 2016
