Sorry...It's off the subject but I have to ask.What's the added toggle switch for?
Actually it is one of J Dots custom made Yaw Switches.
It's really simple to install (plug and play) and only takes a few minutes and JDot's slow yaw switch is fantastic. I've got one on my P2V and it works flawlessly. Highly recommended.Thanks for the info. It looks interesting but I've only had my P3S for a little more than a month so I'm not ready to start modifying it yet.
are those holders adjustableI would buy an Inspire 1 mobile device holder but it requires you to drill a hole in your RC. See the post here. If you have more questions, just ask. Very simple to do...
The Inspire holder? Yes they are. The top is spring loaded and will hold a phone or a tablet.are those holders adjustable
I can mount that on my standard transmitter?The Inspire holder? Yes they are. The top is spring loaded and will hold a phone or a tablet.
Yes you can but you need to mod it by drilling a 1/4" hole for the nut. See the link I posted in this same post for more details.I can mount that on my standard transmitter?
Yes, with a little modifying. It is pretty easy to do. You drill a hole, use a threaded nutsert or a regular nutsert if you have the hand tool to install them. I don't own the tool so I went with a threaded type. I cut the plastic away with a razor knife and drilled a pilot hole. I enlarged it to the correct size and installed the nutsert, tightened it all up and closed up the shell. Then you can mount the Inspire holder. Took me about 15 minutes to do.I can mount that on my standard transmitter?
Can I ask where you purchased the holder and nutsert from? I'm gonna do that for sure.Yes, with a little modifying. It is pretty easy to do. You drill a hole, use a threaded nutsert or a regular nutsert if you have the hand tool to install them. I don't own the tool so I went with a threaded type. I cut the plastic away with a razor knife and drilled a pilot hole. I enlarged it to the correct size and installed the nutsert, tightened it all up and closed up the shell. Then you can mount the Inspire holder. Took me about 15 minutes to do.
View attachment 38290 View attachment 38289 View attachment 38291 View attachment 38292 View attachment 38293
