T Motor issues with V2 props
I just noticed that my two black dot (stock) props screw on fine to my new T Motor Antigravitys. The two silver props don't go down all the way. They are tight and are secure, but they sit higher then the black dot props. Is this okay? Any known problems with this setup? Thank you.
Mine did the same at first, you'll need to give them some more torque to get around the paint on the threads, but they should get to the point they screw down as far as the black ones. You can take them off and try getting the paint of the threads with rubbing alcohol if necessary
wkflysaphan4
