T-Motor Anti-Gravity MN2214-11 Rotation
Sorry if this has been asked before, but I'm upgrading my motors to the MN2214-11 and while I understand the wiring situation between the CW and CCW motors, two of the prop nuts thread normal and two of them thread reverse. Which thread direction should I use for CW spinning motors and which should I use for CCW. I'm thinking that if the prop/motor spins CW, I want the prop nut to thread on opposite of that so it doesn't back itself off. Does it matter? All the stock nuts thread on standard, righty-tighty.
Thanks in advance for the help.
I just installed this motor yesterday. Clockwise motor screws tighten clockwise. Counter Clockwise motor screws tighten counter clockwise. This is in the direction of the propeller spin.
Prop direction indicators are on your Phantom's arms. You can also check out the Naza motor check for prop direction.
shimuafeni fredrik
