Swapping SD cards
Discussion in 'Standard/4k Discussion' started by ChrisRN, Sep 29, 2015.
  1. ChrisRN
    The 8gb micro sd card that came with my standard fills up rather quickly so I wanted to swap out for a 64gb class 10 card. Are there any important files on the factory card that I need to transfer over to the new card, or can I pop out the old one, install the new one and fly?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Just pop the new one in and fly.
  3. Timritchieblue
    I have (2) class 10 card that are 32gb, phantom says slow card? How do I fix that?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    What kind of cards are they?
  5. Timritchieblue
    San Disk ultra 32GB MICRO SD HC I
    Is their a better card to buy?
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The Ultra is too slow. If going with SanDisk, you'll want at least the SanDisk Extreme. You can find a list of other commonly used memory cards here.
    #6 msinger, Sep 29, 2015
    KCadby and robiefield like this.
  7. Timritchieblue
    Thanks, I'll buy some better ones.
  8. JerEl
    NW Florida, USA
  9. Timritchieblue
    I bought a OV 32gb class 10 80MB/s for $16,, figure I would try one.
  10. robiefield
    Thank you to the OP and thank you to msinger. I had exactly the same question about SD requirements because I filled my 8GB SD up, too. I wondered whether any files were required on the newer, larger card. This conversation has eliminated one more area where my knowledge needed help. All the pieces and parts worked here so nicely. Very cool.
    KCadby and dirkclod like this.
  11. Matthewd5
    I have a bunch of the San disc 64's that I use in my GoPro 4's, I had pretty good luck with transcend but never with the fast San discs
  12. zezrum
    Colorado, USA
    When planning on using a new SD card for the first time, I recommend using the Format option in the DJI GO app, just to make sure that the card is clean and that the device can read/write to the card okay. Especially if you've used the card in another computer first.
  13. Matthewd5
    Excellent advice, always try to format the cards in the device their going to be living in
    Matthew
  14. Jescam23
    On my p3s I bought a SanDisk 64gb sdxc ultra and it only shows invalid card. I have tried formatting on the dji go app and still shows invalid.
  15. mfiacable
    Had the same issue with scan disk 64gb. Could not format on go app. Had to return bought a Sony 64 cost a bit more but installed and worked didn't even need formatting.
  16. buford
    I don't know if it makes a difference, but I always format the cards in a gopro, not the drone, and not my computer. I don't know if the gopro wipes them clean or what, but I have formatted in pc, and drone, and come up with trash on the card. Like a freshly formatted card saying the card has no room, except when ots done in the gopro.
Similar Threads - Swapping cards Forum Date
Swapping USB Board between GL300A and GL300C - does it work? Pro/Adv Discussion Mar 9, 2017
Swapping a pro4 motor with a 4 motor. Phantom 4 Pro Help Jan 20, 2017
Swapping Camera for Phantom 3 Professional Pro/Adv Discussion Jan 19, 2017
Swapping compasses Pro/Adv Discussion Dec 29, 2016
P2V swapping radio tx module in remote controller Phantom 2 Vision Mods Dec 9, 2016
