Finally put this to music and logo bookends in after effects. (Blocked in some countries cause of shortsightedness....)
I was in a parking lot. Using L-Com antennas and Rf-Linx amps to penetrate through all the trees. 80%+ of the flight was below horizon of ground.where did you take off/land to get these shots there good. but i have a hard time finding places to take off.
Antennas:how much dose that Com and Amp cost?
If I'm not using the intelite panel I'm using the car set up. Yes, it will cut through objects most well. You will certainly notice the difference. The Rf-Linx amps have a 20db RX value. That RX boost is where it's all at. The TX value is 1.5 watts, but the control signal is usually not an issue, the RX is important so the video feed isn't lost.and you feel like it helps a lot?
