MRSpyder2U said:If you have a Dremel Tool with a cutting wheel, you might be able to cut a slot in the top of the screw and use a flat-blade screw driver to back it out. Another thing to try is screw extractors/easy outs. They're basically screws with reverse threads that can be used in the hex opening to back the screw out as the extractor is tightened.
Kakou67 said:You can try to warm the screw with the tip of a soldering iron.
