strangeness
Atlanta GA
just finished installing my fpv system,, took it real slow,, checked things the whole way through,, then put it back
together,,went to rc assistant, then other assistant, told me I needed to update firmware,, did it.. went out to fire
it up.. and my throttle is now on the left and when I did get it up a little it didn't stay up, its like im in mode 2,, very disturbing I was so hesitant to upgrade firmware but did it anyway.. ive gone back into software many times, but still the same
problem,, calibrated many times.. any help appreciated. thanks
In your RC Assistant check and see which Stick Mode you're in. In Mode 1 the throttle will be on the right, in Mode 2 it'll be on the left. Also make sure your switches are all the way forward on your controller (GPS Mode)
wkflysaphan4
