Strange WiFi Issue
Discussion in 'Phantom 2 Vision + Help' started by ctfeet, Dec 12, 2015.
  1. ctfeet
    Yesterday I was flying my P2V+ and had an issue with the wifi.
    My first flight I did the drill -- remote on, range extender on then phantom on. Got satellites and did
    compass calibration. Flight was good. Got a video and took some stills. DJI Vision app on my phone worked good. Ran battery down, landed it (not exactly graceful, but not rough by any means) and powered it down.
    Swapped battery for second flight, repeat process except for compass. Only problem is the DJI Vision app doesn't show bird battery, SD card or number of satellites. I do get an image from the camera, but the camera
    is pointing down and I can't move it with the app. The bar on the app shows as if the camera is all the way up and I can't move it. But like I said, I do have an image from the camera. I looked online and saw something
    about re-binding the camera to the range extender so I tried that. The rebinding went OK, but the problem is the same. Image from camera, wifi status full bars, range extender battery 90% but no satellites, no SD card
    and no bird battery status. Still can't control the camera - it points down but app bar shows as if camera is all the way up.
    Anyone have any suggestions as to what I can try?
    Stan
  2. kirk2579
    Girard. ohio
    verify the ribbon cable and the 3 connectors on gimbal are completely inserted and tight.
  3. ctfeet
    That was it - thank you very much!!
  4. kirk2579
    Girard. ohio
    glad it was simple & cheap!
    good luck and have fun flying!
Similar Threads - Strange WiFi Issue Forum Date
Wifi Extender discharges strangely fast??? General Discussion Sep 25, 2014
Strange behavior at higher speed Phantom 4 Discussion Today at 7:43 AM
Strange Startup error on my P3A Pro/Adv Discussion Aug 3, 2017
Has anyone else made this strange mistake? Phantom 4 Discussion Jul 15, 2017
Strange noise on Gimbal Phantom 4 Help Jul 10, 2017
