Strange Gimbal Gyroscope Error - But only sporadically
Discussion in 'General Discussion' started by mammatus, Jul 11, 2016.
  1. mammatus
    Good Morning,
    I have been flying my Phantom 3 Standard for about five months now and love it. It's always performed beautifully for me. However, last week, I encountered a new problem that I can't seem to shake.
    After several successful flights just the day before, I took it out for a flight at the beach and when I powered on the bird, I noticed the gimbal remained limp; it didn't do the usual little startup 'dance'. The error message on the tablet indicated a "Gimbal Gyroscope Error" and that service was needed.
    Sad, I packed it back up and took it home. However, later in the day, I brought it out to try again. After several restarts, on the fourth or fifth start, it started up normally! I was able to successfully fly and record on Independence Day.
    The problem continues though. Whenever I want to fly, I have to restart / shutdown / restart the bird several times before it ultimately starts up successfully. Once this weekend, I had to do this about a dozen times before the gimbal responded normally.
    Short of mailing this thing in to Phantom, are there any fixes I can attempt on my own? I'm not super-savvy with electronics, but I'm not afraid to dig into it if someone can point me to some specific areas to address.
    Thanks in advance for helping me out.
  2. Multicoptertec
    Apollo Beach, Florida
    Couple of things. Run calibration routines for gimbal, IMU. Check all cables including ribbon cable.
  3. mammatus
    Great - I'll run all the calibration routines again.
    Are there any diagrams or websites that would show photos of the cables to check?
    Thanks!
  4. Multicoptertec
    I'm sure there are photos out there, but there is a multi wire cable (gray) and 2 coaxes going to the gimbal assembly. Check for any damage or loose connector. The flat ribbon cable around the gimbal can be partially inspected.
  5. alokbhargava
    San Francisco, CA
    Seems to be a loose gimbal cable.
  6. Traveler
    You can get a good view of all connectors and cables if you watch a how to repair a DJI Gimbal video. Google and you will find several. You won't be able to access all connectors without rebuilding it, but if you have a damaged cable you will be looking towards these self help videos anyway.
    Good luck
Similar Threads - Strange Gimbal Gyroscope Forum Date
Strange noise on Gimbal Phantom 4 Help Jul 10, 2017
Professional Strange sound from gimbal Phantom 3 Help Jul 5, 2017
Gimbal doing strange things on start up Phantom 4 Discussion May 28, 2017
really strange unbalanced gimbal issue Pro/Adv Discussion Apr 19, 2017
Strange Gimbal Problem Pro/Adv Discussion Jan 8, 2017
