  1. doctordrone
    Bay Area, California
    Just noticed this with P4. In the DNG image, when I increase exposure or shadows in PS, all these (mostly magenta) pixels show up in the darkest shadow areas... any suggestions? I tried DJI DNG cleaner... no change.
  2. sar104
    Los Alamos, NM.
    What you are seeing is normal - you are trying to pull information from the shadows that is simply not there due to the limited dynamic range of the sensor. The pixels in question are nearly black, and when you try to lighten them the resulting color is mostly amplified noise.
    randykahl likes this.
  3. doctordrone
    Ok, I'm following you. Is there an efficient way to clean that up? Or is it just spot healing each pixel?
  4. sar104
    Los Alamos, NM.
    I don't know any way to fix that. The information is just not there in the original files. The RAW images may have a higher bit depth than 8 bit JPEGs, although I haven't seen the specs anywhere, but clearly not enough for that scene. If you want to see those kinds of shadow details then you need to increase the exposure, but that, of course, may result in blown highlights - the ubiquitous problem with high dynamic range scenes.
    #4 sar104, Mar 26, 2016
  5. thegoodtouch
    I would clone stamp them out for existing pics and then focus on getting more data out of your pictures on the day for future shoots
  6. sar104
    Los Alamos, NM.
    It appears that the Exmor sensor in the P4 has a 12-bit dynamic range, but having compared some P4 RAW files opened in 16 bit space versus 8 bit space, I'm struggling to see much difference.
  7. WetDog
    There is program wandering about on the DJI site called DJI DNG cleaner or something like that (can't look it at present). It will help with the hot pixel images. But sar104 is basically correct, you're down in the noise on a not very sophisticated (for 2016) digital camera. Maybe you could add a bit of fill flash ....
  8. sar104
    Los Alamos, NM.
    Agreed. It's not at all bad for a point-and-shoot 1/2.3 sensor, but it's not going to do well at pulling detail from deep shadow, even with raw image data available. I haven't tried it, but it does have an HDR option - that would be another way to increase the dynamic range.
  9. WetDog
    The HDR option is pretty worthless. You are better off using AEB (automatic exposure bracketing) and manually combining the images. But even that is pretty limited because it only steps the exposure in 0.3 EV unit increments (or maybe 0.7). You really want 1 or 2 units of change. Manually bracketing is a slow process and something that would only work for a very static image and stable drone.
    There are just limits to what you can do with the sensor.
  10. sar104
    Los Alamos, NM.
    I hadn't tried AEB either but, having just tested it, it will do either 3 or 5 shots at a separation of 0.7, giving up to 2.5 stops of bracket. Better than nothing.
Similar Threads - Strange colored pixels Forum Date
Strange Startup error on my P3A Pro/Adv Discussion Aug 3, 2017
Has anyone else made this strange mistake? Phantom 4 Discussion Jul 15, 2017
Strange noise on Gimbal Phantom 4 Help Jul 10, 2017
Strange behaviour from phantom 3 std RC Standard/4k Discussion Jul 8, 2017
Professional Strange sound from gimbal Phantom 3 Help Jul 5, 2017
