Strange behaviour
Discussion in 'Phantom 2 Discussion' started by Realist, Jan 5, 2015.
  1. Realist
    Wales UK
    Hi guys,
    Currently on a 2 days short visit to the Scotish highlands right on Loch Lochy. Brought my Phantom with me for some pics but.......
    Calibrated, found satellites all looks ok but on take off it went to the rear and flew into a bush, 2nd attempt it attempted to lift off but one side went straight into the ground.
    I didn't try again after that because didn't want to risk it flying into the Loch which was 40ft from take off point and loosing it for ever.
    Any ideas of the problem.
    I did calibrate the controls before I came up here and I don't have access to a PC to try it.
    As a side note I did attempt to install my tracker internal and take a feed off pins 1 & 2 on the naza and slipped with the multimeter, the drone did throw a wobbly, bleeped a few times so turned it off quick.
    All looked ok at hone, didn't try a test flight so may have buggered something but gota wait till I get home.
    Regards
  2. Realist
    Wales UK
    Also when I flick S1 to start the calibration I don't get the quick flashed of the green lights?
  3. Buckaye
    Orlando
    you're flicking S1 more than once correct? it take's 5+ flicks to get to the tootsie roll center of a tootsie pop (sorry - american commercial joke) -
    meaning the calibration trigger is more than 5 toggles of the S1.
  4. Realist
    Wales UK
    Yep normally it starts to kick in after 6 flicks but some unknown reason nowt happened?
  5. Realist
    Wales UK
    Here is the video from the crash where it went backwards and crashed then on the 2nd attempted went to one side, didn't try again after that.
    [youtube]https://www.youtube.com/watch?v=-kwXzsEJN-c[/youtube]
  6. Buckaye
    Orlando
    I'm a little worried about the above and the fact that you aren't getting the right lights upon calibration.... it certainly sounds like you could be having a calibration issue - I don't know what kind of magnetic fields there are in that area...
    unfortunately - since you aren't at home - the scientific method is a bit hosed because we have at least two variables to worry about.
    1. the weird bleeping when you were installing the tracker and not knowing that your Phantom flew fine at home after that event
    2. That you can't seem to calibrate where you are (again - not being able to compare that to home).
    Maybe someone will see something in the video that tips it off
  7. Buckaye
    Orlando
    oh and well done on the song choice.... I just played with sound LOL
  8. Great Pumpkin
    Santa Barbara County, California, USA
    Realist (and Buckeye),
    Some of us might be able to offer some ideas of your problem if we knew exactly what DJI product you are flying, what accessories it has, what modifications you've made, and its crash history. It would be helpful, too, if you would add your location to your profile.
  9. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Errr... those rocks you're taking off from... odds are good that some of them are ferrous. Which is bad. Especially if you calibrated your compass anywhere near them.
    Replace damaged props, inspect for physical damage, carefully recalibrate your IMU and compass and take off from a non-ferrous surface. All will be well.
  10. jason
    Commerce Twp,MI
    Were pins 1 & 2 on the naza used to power your tacker? You may have damaged the naza when you slipped and that is what is causing your problems.
  11. Realist
    Wales UK
    Ok its pitch black here in sunny Wales (night) but I've carried out the following as a test.
    I've recalibrated the compass via DJI Phantom 2 Vision Assistant_3.4 software that came back all ok.
    Went outdoors and flicked the S1 and this time the lights went yellow and the Phantom calibrated all ok but only found 5/6 satellites and kept flashing red/green.
    Behind my house is a large patch of green so I went there for a clear line of sight and calibrated it all over again and this time it found 8 satellites and the lights flashed green, great :).
    But...............
    On take off the drone is still has more lift at the front (camera end) and the back (battery end) drops down so I gave it a bit of power on the throttle and up it went.
    It levelled out ok, didn't drift to one side as it did a few days ago but hovered in a 6ft range not still so.........
    I think because its heavier now with the extra mini iosd and a 2.4Ghz data link its effected the weight and its now causing a lift issue.
    Any ideas?
    And thanks all :) great help so far.
    Brian
  12. ianwood
    Staff Member
    Lost Angeles
    Yes. Don't take off on ferrous rocks!
  13. Buckaye
    Orlando
    +1
  14. Realist
    Wales UK
    Point taken about the rocks, video of tonight's test.
    [youtube]https://www.youtube.com/watch?v=9Qwzf8YNSps[/youtube]
  15. Realist
    Wales UK
    Lens was dirty from the grass but its struggling to lift off and tilting towards the battery end hence I had to give it full power to get it airborne.
  16. Buckaye
    Orlando
    I do have the product I'm flying in my profile :) Also - since this was in the Phantom 2 - non-vision forum - I was assuming that is what product realist was flying...
  17. Realist
    Wales UK
    Its the Phantom 2 - non-vision
  18. Buckaye
    Orlando
    in general you really want to goose it on takeoff anyway - once it got in the air, it looked pretty steady (from what I could see in the dark).... were you having to do a lot of controller input to keep it steady in the air? or was it that steady with little/no input?
  19. Realist
    Wales UK
    It needed a bit of a wheelie to get it off the ground but as above it tilts to the battery end like its not lifting off the ground evenly.
    Once its airborne its moves about a bit, will do another better test tomorrow when its light.
    Thanks guys you have all been a great help much appreciated.
  20. Great Pumpkin
Similar Threads - Strange behaviour Forum Date
Strange behaviour from phantom 3 std RC Standard/4k Discussion Jul 8, 2017
Strange behaviour of my P3P Pro/Adv Discussion May 22, 2017
[solved] Strange (and dangerous) behaviour of a RC Standard/4k Discussion Sep 12, 2016
Strange behaviour Pro/Adv Discussion May 8, 2016
Strange Behaviour in cold weather - Could this cause a crash Pro/Adv Discussion Jan 21, 2016
