Stock RC upgrade question FPVLR
Discussion in 'Phantom 2 Vision + Discussion' started by Jazziet512, Dec 26, 2014.
  1. Jazziet512
    Rc upgrade
    I am about to install the FPVLR stage 2 mod for the wifi and stock RC transmitter.
    I am somewhat nervous about tackling the rc upgrade because of all the stories I've read about the black goo of death. I don't want to break the connector when removing the goo.
    So, is there somewhere that I can get an rc module with the connector already removed? I've seen circuit boards on eBay for the Phantom with the connectors already removed, so wondered if there was such a thing for the rc?
    Also, I'm quite taken with the Futaba rc's, but I think I'm right in thinking that these only operate on 2.4Ghz which is no good for the Vision 2plus as it operates on 5.8Ghz
  2. saao
    The black glue is in the receiver side in the bird. The transmitter has the White glue if done properly with a sharp blade can be done easily just be patient and once u feel the wire is rotating you will know your close enough I did mine both receiver and transmitter it took me around 1 and half hours for the receiver end is more difficult but nothing is impossible bro best of luck both
  3. saao
    The rc works on 5.8 and the wifi works on 2.4 if you choose the 2.4 frequency I believe it wil interfere with the wifi not recommended
  4. Dirty Bird
    Glen Burnie, MD - USA
    I believe I saw on ebay a guy selling replacement 5.8 Ghz Vision+ receivers that already have the antennae disconnected. Been a while so you will need to look. Not sure why DJI insists on selling replacements with the antennae already glued?
    Can't use a 2.4 Ghz Futaba with the Vision+ 5.8 Ghz receiver.
  5. GSSP
    a razor blade is almost to big, I used a surgical scalpel. many have tried acetone to soften gue
  6. Jazziet512
    Great - thanks for all the replies - guess that I'll just have to be careful with scraping the goo away!
  7. GSSP
    you can get a cheap scalpel off amazon, it is very fragile connector
Similar Threads - Stock upgrade question Forum Date
Best way to upgrade to a camera/gimbal? P2 stock Phantom 2 Discussion Dec 27, 2016
9342 ft , Stock remote... Phantom SE Jan 6, 2018
Longest distance bone stock 31015ft Phantom 4 Discussion Dec 6, 2017
Longest Flight All Stock 30205 ft one way Phantom 4 Discussion Dec 5, 2017
DJİ P3 PRO - Stock Battery One Direction Range Test Pro/Adv Discussion Nov 23, 2017
