Hi
Still newbie trying to understand Failsafe RTH
manual says
The Forward Vision System allows the aircraft to create a real-time map of its ight route as it ies. If the Home Point was successfully recorded and the compass is functioning normally, Failsafe RTH will be automatically activated if the remote controller signal is lost for more than three seconds. The aircraft will plan its return route and retrace its original flight route home. The aircraft will hover for 10 seconds at its current location. When it regains signal connection it will wait for pilot commands. The Return-to- Home process may be interrupted and the pilot given control of the aircraft if the remote controller signal connection is re-established.
So signal is lost and AC starts home, got it
Then if signal re-established pilot can interrupt RTH and take control, got it
but what do the two underlined sentences mean?
when does it hover 10s?
if when the signal is re-established it waits, then there is no need to interrupt...
so how do the two underlined sentences fit?
thank you
manual says
thank you
