- Joined
- Sep 12, 2016
- Messages
- 22
- Reaction score
- 2
- Age
- 39
My settings were defaults/Auto across the board. I made a few changes shown below.What are your current settings?
DNG in fact IT IS a RAW image.The "RAW" isn't really raw. It's a .DNG and contains the same metadata as the jpegs.
For mapping, jpeg is appropriate. Raw will cause the continuous capture to be too slow and you will not gain much in quality of the end-result as long as the capture is correct. Using eg DroneDeploy at full auto during good daylight, it will capture at f/6.3 ISO 100.So my question in this thread has been about photography but my main reason for purchasing the p4p is for mapping. I believe i need to shoot jpeg to get the exif data to attach to the image files while mapping. I set it to both Raw and jpeg to see the differences between the two.
Can you guess which photo is from which craft?
JPG is processed and compressed by the camera hardware.
DNG/RAW is a file with all the data recolected by the sensor, uncompressed (or lossless compressed) and without any process, like a "digital negative". You are in charge to do the final processing.
Metadata it's the same because metadata it's a text embedded with shoot information (aperture used, ISO, shutter speed, focal lenght, location, etc)
DNG is a filecontainer which contains the raw sensor data as well as metadata. All, or at least the more common, raw formats (the file containers) include some metadata including exif..DNG is a file extension that includes data not included in a true RAW. A true RAW is in fact raw sensor data. It is not a file type and does not include exif data. The .dng includes gps data, lense corrections, etc.
