Split 2.4ghz antennae on controller.
UK Brit living Latvia
Various mention that possibly the two antenna swap active depending which has stronger signal.
This then brings to a thought - if you have for example Argtek mod fitted. Maybe angling each 2.4 slightly different will give you better coverage as you move about, controller will never be fixed attitude.
Its just a comment - I tend to feel its not simply swapping antenna - I think there is more to it than that. The 2.4 is carrying a lot more two way than the 5.8 ....
Nigel
cokersean20
