Hello,
I had a incident on Sunday and splash out my gimbal system with fresh water. The drone 4 motors are working fine, the camera is transmitting but the roll and pitch motors cannot position the camera. Both motors do some noise like they are trying to align the camera and after a couple of minutes it shows the alarm "gimbal motor overload". When I start the drone the camera does move in all directions. When I use the gimbal dial, it does not moves up and down the camera.
Questions:
1. Could it be that the motors are ok and the electronic is the problem? I could replace the 2 motors control boards only or if it is an issue with the control board, maybe if I clean it with alcohol, it could help?
2. Could it be that the water damaged partially the motors, so they are trying to move, but something is wrong with the motors? Then, I would need to replace the motors
Or maybe is just both, motors and control boards.
Thanks for the help!
Questions:
