Sorry to be a NOOB.. but.. .P4 sensing prop guard?
hey all.. first 3 days of P4 flight.. have something going on.. i believe beginner mode is off.. i find that when pushing the right stick up to move forward it starts then juts back as if something were in the way?
doesn't happen all the time, but could it be the prop guard?
whats the fix? I also get a single beep from the controller/ipad setup when it happens..
Thanks in advance
RLB
You'll have to disable Obstacle Avoidance in the Go App when using prop guards
Check your main controller settings. Although you may have beginner's mode disabled, you may have Max Distance enabled which limits flight to a distance of your choosing.
OAS sounds like the culprit. That's a shame.
But I will check my settings regardless.
Thanks!
mactechnic
