[SOLVED] Use P2V+-cam on P2V?
1. Is the name DJI Phantom 2 Vision or DJI Phantom Vision?
2. Is it possible to use the P2V+-camera+gimbal on the P2V? This one:
http://i.kinja-img.com/gawker-media/ima ... prj7tp.jpg
P2V doesnt have the same Wifi-Module...
There are three cables from the gimbal-card. One that splits to CAM onto mainboard and the other to the Wifi-module.
Cable two goes to the Wifi-module. And the third cable goes to the little board on the mainboard.
Re: Use P2V+-cam on P2V?
In the P2V, the camera and wifi module are all in the same unit.
In the P2V+, the camera and wifi module are separate. To upgrade the P2V to a P2V+, you'd need:
- camera/gimbal assembly with mounting bracket
- grey 3-ribbon cable set
- anti-interference board with its cable
- wifi module with the extra cable to the mainboard
- antennas for the wifi module
Thanks. I had opened both Phantoms and then I got it pretty quickly. :)
My plan is to skip the gimbal (doesnt seem to work, but I guess it should, if there was en egg-camera FC200) and replace it with a GoPro-gimbal + other video-link + ...
