- Joined
- Dec 15, 2015
- Messages
- 9
- Reaction score
- 6
- Age
- 40
Hope someone can help me...about to loose my mind over this -.-
Opened my Phantom 2 and installed the following hardware:
- iOSD Mini
- FrSky X8R receiver for my Taranis Plus
Everything worked fine but then I decided to change some things so I can fit
everything inside and not having the receiver and the iOSD hanging around the outside.
I moved the gimbal anti interference board inside too, hooked everything back up
and now I get the really loud beep and no start up frequency when powering up.
Everything works fine: I have my FPV picture on my monitor, also the iOSD overlay, gimbal tilt
control works and when I connected to my computer all other controls and even switching
in between flight modes or activating the failsafe works with no problem.
I just can't arm the motors and the beeps start out as one single beep but are actually 4
which I can hear after some time because they loose sync.
My guess is there must be some wire loose, but I checked everything and can't find a
loose or broken connection anywhere. Checking continuity is nearly impossible, since all the solder joints
are made non conductive with some transparent paint or glue...
What could be wrong here?
- iOSD Mini
