SOLVED! Ever seen a gimbal doing this?
The Netherlands
Hello guys.
I was busy with my drone and for a long time the gimbal was hanging a bit to one side. It is a Chinese gimbal and I saw someone on here using the reset button to straighten it. But I think I did end the procedure to soon (unplug the battery). Now when I turn it on it does this:
https://m.youtube.com/watch?feature=you ... SKTysNqq2s
Did I wreck it? Is where a way to calibrate it correctly? It has a mini/micro usb connection. Can I re-install some software on it? Or do I need a new board?
Btw if I unplug the compass it does get less violent.
Re: Ever seen a gimbal doing this?
Last time i saw this on a youtube video, it was because the wires were plugged in wrong, the pitch and roll cables were either reversed or on the wrong sockets, the gimbal tries to level the camera but sends the motors in the wrong direction.
You should probably run the GUI software for the gimbal and verify the settings.
(Search for "gimbal gui software". It's probably either simplebgc or basecam.)
Oeh nice. Need to find all that out. I'll need the custom null firmware or something like that. I'll try to re-flash the thing this evening.
Ok. I got it somewhat working again. Re-flashing didn't work but fooling around in the settings did work. The gimbal is now 180 degrees off (from the naza setting at about 135 degrees down with the naza unplugged... Strange) it's now stabilizing again. But I can't get the gimbal to turn to normal view. As you can see the pitch control doesn't make sense. It isn't even trying to bring pitch to zero. Calibrating didn't work.
https://m.youtube.com/watch?feature=you ... bE9rGasA9Y
Is there some setting I'm missing? (Invert?) I'm quiet new to this but I actually really enjoy doing stuff like this.
Edit: this is what it's doing now. It looks like it's going to face forward but then keeps tilting back.
Calibrating in different angles doesn't do anything.... It does accept the calibration.
https://m.youtube.com/watch?v=-DkE5ii6a ... ata_player
Another edit...:
Well, A new controller including firmware... I think i'm just going to order one from ebay. Its just a little bit over 8 dollar.
http://www.ebay.com/itm/BGC3-1-2-axis-C ... 2595fc07a1
Ok it's working again! I needed to invert top axis from Z to -Z. Now fine-tuning comes in. I've given the gimbal motors some extra power (about 60/70%) and now its a little bit stronger to resist agains the cables.
Anyone care to share a screenshot of the PID setting of a stock chinese gimbal? 2.2b2 I believe this is a Alexmos board whatever that means.
