[SOLVED] Battery: Change cell-pack <-> electronics?
Discussion in 'Phantom 2 Vision + Discussion' started by MickeM, Jan 18, 2015.
  1. MickeM
    Is there any dont's about changing the cellpack with another?
    That is... I got two batteries, one with faulty cellpack, and one with faulty electronics.
    Can I change? Im used to weldning (two cables only). Im aware of the fire hazard.
    Another question... the first battery is a original DJI 5200mAh LiPo and the other is a 5400 mAh Ttongr-LiPo.
    I would discharge these and throw them, but the owner really wants one to work.
  2. Bigdz
    Ca
    Re: Battery: Change cell-pack <-> electronics?
    My original battery that came with my bird flashed on my screen during today's flight "battery error" bad cell. It has 50 flights on it. Battery percentage life says 91%. I purchased it back In June of 2015. Thought battery would last longer but obviously not.
    I have 4 more. All solid, and one of the four I just recently purchased from limefuel. Which by the way is a solid battery with 12 month warranty. Of course, I will not connect it to the assistant software. I plan to buy a few more of their batteries especially new one coming soon.
    I have now experience with replacing cell packs in batteries but I wouldn't take the chance. Just get a new one or maybe see if batteries still under warranty
  3. MickeM
    You are right. It is a bit risky to change electronic boards between two batterypacks that arent working well (although the cells are good at around 3.8V/cell).
  4. CityZen
    NYC
    Should be okay to change out the cells (assuming you know what you're doing). There are threads about separating the battery circuit board from the cell pack so that you can use regular batteries with the Phantom 2. http://www.phantompilots.com/viewtopic.php?f=27&t=28112
  5. Doru Brad
    Oradea, Bihor, Romania
    I can confirm it works! Just swaped a bricked Ttongr electronics with a original DJI one froma "dead" battery. All you need is TO SWAP THE GROUND AND DATA AROUND as Ttongr has them reversed! Now my 5400mah Ttongr with stock DJI electronics works perfect with LATEST PHANTOM firmware!!!
Similar Threads - [SOLVED] Battery Change Forum Date
Advanced [Solved] Major battery voltage deviation - Opinions pls :-) Phantom 3 Help Mar 8, 2016
[SOLVED] Battery: two middle LEDs on Phantom 2 Vision + Discussion Jan 18, 2015
[SOLVED] Battery problem -> Land Phantom 2 Vision + Discussion Dec 26, 2014
[Solved]Phantom 2 assistant won't connect after motor replacement Phantom 2 Help May 3, 2017
How do you get the log files out of the P4P+ controller? [SOLVED] Phantom 4 Pro Discussion Dec 31, 2016
