Solution for vibration and Jello on H3-3D
Argentina
Hello to Everybody:
The "Perfect vibration and Jello solution" for Phantom 2 H3-3D :
1) Rubber isolant washers between Phantom and Gymbal plate.
This separate the third motor of the Gymbal from the Phantom Battery.
and reduce vibrations with the washers.
1.1) Little soft rubber washers between gymbal screws heads and plate.
This make the Gymbal devoid of rigid fixation to the Phantom
2) Use White dampers
2.1) Connect: Anti interference board between Phantom and Gymbal
2.2) NOO!! security spins on Dampers , the white dampers are sure enough to
hold the gimbal by themselves, and this reduces a lot of vibrations and
friction
2.3) Carbon propellers are better and balanced, or balance in a Hobby shop your propellers
3) Flying in no strong wind days.
3.1) Gopro 1080 30 p mode
4) You obtain a Little smooth video with no GPS mode
With all this cautions you get a very very smooth video!!!
http://www.aeroimage.com.ar
Have....... sunny and quiet flights!!!
shimuafeni fredrik
