SOLD DJI Phantom 2 - needs parts to fly
Status
Not open for further replies.
Manchester, NH
DJI Phantom 2 quadcopter (version 1) $300
Buyer pays for shipping. I am located in NH
This is the first generation Phantom 2 that was designed for the Zenmuse H2-3D gimbal. I am including the DJI Mounting adapter and extended legs (unopened) to mount the new H3-3D 3 axis gimbal.
This unit is fully functional and only has a few flights on it. Never been involved in a crash - the only problem is that the mounting posts on the bottom shell were corroded by blue threadlock. A new shell is optional but not required for the drone to fly.
The top portion of the shell can still be secured using the remaining screw holes at the end of each arm.
Video of unit working: https://www.dropbox.com/s/pi5wchcoai70z8o/2014-09-03 00.39.25.mp4?dl=0
Photos:
https://www.dropbox.com/s/z5rkz2zf0s5akc2/2014-09-02 20.32.35.jpg?dl=0
https://www.dropbox.com/s/b9nnp0x0pklcimp/2014-09-02 20.32.13.jpg?dl=0
https://www.dropbox.com/s/yodiwekqxk4aixr/2014-09-02 20.30.58.jpg?dl=0
https://www.dropbox.com/s/3ia6p5yrsgtlksu/2014-09-02 20.40.24.jpg?dl=0
https://www.dropbox.com/s/t1mc4j8836v2tb4/2014-09-02 20.28.44.jpg?dl=0
https://www.dropbox.com/s/vs1rckp7lj6husl/2014-09-02 20.30.41.jpg?dl=0
https://www.dropbox.com/s/jqqehs25zoze1u8/2014-09-02 20.45.59.jpg?dl=0
https://www.dropbox.com/s/4nc2kzswr77oao4/2014-09-02 20.28.04.jpg?dl=0
There is a hole in one of the vents on the bottom shell that was used for wiring.
Items NEEDED to fly:
DJI Smart Battery
DJI Propellers
Optional:
New outer shell.
This does not include the gimbal or camera.
Comes with original box and manuals. Also included:
DJI FPV Hub - easily connect your video transmitter for FPV without the need for soldering.
DJI Prop guards - protect the props from hitting objects.
General Features:
Quad-rotor System
Customized H3-2D and H3-3D Gimbal Support
Precision Flight and Stable Hovering
25min Flight Time & Smart Battery
Auto Return-to-Home & Landing
Advanced Power Management
Intelligent Orientation Control (IOC)
Easy Battery Replacement
Self-tightening Propeller
Video Downlink Support
CAN-Bus Expansion Module
Aircraft Weight 1030g
Hover Accuracy:
Vertical: 0.8m;
Horizontal: 2.5m
Max Yaw Angular Velocity
200°/s
Max Tilt Angle
35°
Max Ascent / Descent Speed
Ascent: 6m/s; Descent: 2m/s
Max Flight Speed
15m/s(Not Recommended)
Diagonal Length
350mm
Flight Time
25mins
Controller requires 4 AA Batteries
Status
jrl
