Software 3.8 assist
Discussion in 'Phantom 2 Vision + Discussion' started by Gosloman, Jan 22, 2016.
  1. Gosloman
    I downloaded; Assist software 3.8, RC Assist 1.2 and Win Driver, attached usb cable to the controller and to the Phantom 2 vision + then loaded the Win driver, the Win drive loaded good then started the Assist software 3.8 and waited about 15 seconds but nothing happened. I am using Windows 8.
    However when I start the RC Assist program the controller is recognized and I can calibrate the controller but not with the Assist 3.8 program, when I tap the gray Phantom tab at the top of the menu a small screen drops down and states " Connect the controller" , NO GO !
    I do not know what else I can do to upgrade my P2V+. Any advise ? Thanks
  2. Johnnics
    Not sure what your trying to do but if you connect the PH2 at front to computer via usb and just turn on remote controller [ NOT connected to computer by usb ] then you will see all the info of PH2 and can calibrate your remote controller if you need to via DJI Phantom 2 Vision Assist software 3.8
    Johnnics
  3. Gosloman
    Thank you for you input, followed you info. all is operating well. Again Thanks
Similar Threads - Software assist Forum Date
Can't Calibrate Phantom 4 with DJI Assistant 2 Software on Mac Phantom 4 Discussion Jul 28, 2017
DJI assistant is unverified software!? Phantom 4 Help Dec 28, 2016
Phantom 2 Assistant Software stopped working Phantom 2 Help Aug 4, 2016
P3A Assistant software? Pro/Adv Discussion May 19, 2016
Standard Gopro assistant software? Phantom 3 Help Dec 25, 2015
