So .... what good is a Windsurfer?
Discussion in 'Standard/4k Discussion' started by gklugie, Jun 25, 2016.
  1. gklugie
    Dallas, Texas
    I bought a windsurfer, and have no range problems that I know of. I had no range problems before using the windsurfer.
    I need an answer to this question: Since the Windsurfer enhances (focuses) the transmitted signals only, the signal reception (handled by the internal plate antennae) remains unenhanced. What is the benefit?
  2. flpholt
    palm harbor florida
    longer range in flying so you can fly out of vlos
  3. WilliamM
    Lancaster, Pa.
    Are you sure the external antenna (5.725 GHz – 5.825 GHz) is only used for transmitted signals. I know it's for controlling the aircraft which determines your range, but thought some data was also received on the frequency. Are you saying all data received is from the wifi only (FPV video and ALL data telemetry)?
  4. gklugie
    Dallas, Texas
    Assuming I am correct ( with only the transmission signal enhanced with the windsurfer), wouldn't I simply lose the aircraft's downlink telemetry at the range where the return signal normally becomes weak?. I hope I am explaining this well enough for you folks to read.
  5. Mark The Droner
    Yes, you are correct.
    To answer the question in your thread title, you'd probably want to modify the controller and bring those 2.4 antennas outside where you can manipulate the signal to benefit your long range goals.
  6. N017RW
    Palm Beach Co.- FL
    Receive or transmit antenna gain is achieved by beam-shaping (directivity).
    Windsurfers are analogous to cupping your hands behind your ears.
    You will definitely improve your ability to hear faint sounds but you must adjust the direction you are facing to 'capture' those sounds.
    RodPad and AgnotGT like this.
  7. AgnotGT
    Santa Cruz, California
    Great explanation! Curious though... Say your bird is lost to your sight and 90* or more to your side or even behind you. Will a windsurfer then hinder/block your connection with the bird?
  8. N017RW
    Palm Beach Co.- FL
    Yes.
    In order to achieve gain in a particular direction peripheral signals must be attenuated to some extent.
    This is the directivity 'factor'.
  9. WilliamM
    Lancaster, Pa.
    You can just pull it off in a second if the need arises.
  10. RodPad
    Pacific,NorthWet, 97031
    Follow this one....
    Question about Radio, uplink, downlink, frequency, & telemetry
    Rod
  11. WilliamM
    Lancaster, Pa.
    I just checked it out, very interesting. This is just the info I was looking for, thanks.
