So I Just Updated the Firmware, Should I be worried
Discussion in 'Pro/Adv Discussion' started by Bateman233, Jul 24, 2015.
  1. Bateman233
    I am a long time flier of the Phantom 2 Plus. Just got the Phantom 3 Professional in today and I stupidly went ahead and updated all of the firmware before checking on this forum....
    Should I be concerned? Sounds like a lot of horror stories on here with the new update?
    ALSO, can anyone please suggest a good thread discussing the best camera setting in certain light ect...
    Thank you!
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    For camera settings:
  3. Albert R.
    Based solely on my experience if you got passed the update and your log files check out you should be ok. My update was not without a significant scare but after that the P3P has been flawless. Make sure you calibrate your IMU, gimbal and compass before your first flight. There are several threads on how to do that proficiently. Then go through all your aircraft settings to make sure things are looking the way they should.
    Hope all goes well
    Below is the link to my update experience.
    http://www.phantompilots.com/index....mware-update-"bug-ridden"?.45742/#post-424502
    #3 Albert R., Jul 24, 2015
  4. Bateman233
    Thank you very much for the links, the second one is a big help. Cheers.
  5. Bateman233
    Thank you for your reply and information. Will definitely follow your advice. At the moment though I am having an issue with finishing the update...it's been beeping for 50 minutes...should only take 25 minutes...should I power down?
  6. Albert R.
    That's what I had to do (power down). Note the link above to my previous post. It was a scary process as I thought I had totaled the aircraft. All the lights turned off and the beeping stopped. All it was doing was generating do weird gimbal noise.
    Based on you initial post, I thought you had already completed your firmware update.
Similar Threads - Updated Firmware Should Forum Date
Updated Firmware last night and now Map will not populate Software Jul 15, 2017
Repaired P3S Firmware Upgrade Via Sd Card? Tx Updated? Standard/4k Discussion Jun 7, 2017
dji P4 updated firmware stuck at 99% Phantom 4 Help Mar 30, 2017
Updated firmware to 1.8 for third test flight , first time over water Standard/4k Discussion Jan 23, 2017
Standard Updated latest firmware, having issues Phantom 3 Help Jan 22, 2017
