I tried to send the following to the FAA via email when I found I could not seem to be able make a formal report using their system, then I found out they will not accept emails about incidents because of "privacy concerns". The first segment below describes the incident and why I wanted to send it and why I couldn't. '
The second segment below is an email I did send since it did not include any privacy information.
Let's see how level the playing field really is.
1st segment
I was recreationally flying my DJI Phantom 3 Professional over my property near Pomona, Illinois this morning at approximately 8:45 AM CDT. While operating the model at approximately 150 ft AGL my airspace was overflown by a what appeared to be a wingover single engine aircraft operating somewhere between 500 and 1200 feet AGL. I immediately brought my model down to below 75 feet until the aircraft could no longer be seen or heard. I continued my model flight with a ceiling of 395 feet and at all times i was in LOS with the model. Less than 5 minutes later, the aircraft reentered my airspace and was considerably lower. To avoid any issues with the aircraft, I landed the model after descending to less than 50 feet AGL.
The problem is that there is no place for a recreational model pilot to report incursions yet there are multiple ways for a pilot to claim they have had a "drone" incident. In this case I want to be on the record that I was operating the model within FAA recommendations and the only person with questionable flight parameters was the pilot of the small aircraft, Thank you for your attention.
2nd segment
How does a civilian recreational UAV owner operating completely within current FAA recommendations report an incursion of a civilian aircraft into his private property airspace which causes the UAV pilot to have to take preemptory evasive action to avoid a possible incident? It would appear your forms do not take that eventuality into account. Thank you,
1st segment
2nd segment
