- Joined
- Jul 4, 2018
- Messages
- 336
- Reaction score
- 78
- Age
- 77
How do I slow down the movement of my Standard. I am still learning and feel it could be a little slower. Can't seem to find a video on it. Thanks
Playing with the expo settings should get the OP closer to the intent of smoother movement without having any impact on the ability to get out of trouble fast. This is simply because changing the expo only alters the rate of change close to the centre or neutral stick position- there is no impact on the effect of maximum deflection and the reduced sensitivity is less pronounced the further the stick is moved. Need to react fast and the only difference might be how quickly you can move the stick. Doubtful it would make any difference to the outcome. The phantoms are very slow to respond in any case.Just remember.......When you need to get your self out of a close call when flying with less sensitive sticks......it wont respond near as Quick and FAST ! " Fly with caution with Less Sensitive Sticks " ! and like barefoot said above....Practice practice practice !
I discovered my sticks were about as short as they could go. I extended them some. I will try that.
