Skins (are they hard to put on?)
Discussion in 'Pro/Adv Discussion' started by sandman259, Aug 25, 2016.
  1. sandman259
    sandman259 Guest
    How hard is it to put them on and to get wrinkles out and make look good? I'm thinking about doing it but seems like it would be hard to put on with it not being flat. And with all the problems with the original decals always coming off and lifting off is it going to be the same thing with the wraps?
  2. J Dot
    Sarasota, FL. USA!
    I put one on once,
    Tx and bird, I used a drop of dish soap, ( dawn ) in a smaller squirt bottle, filled the rest with water, very LIGHTLY mist the shell with the soapy water ( TINY BIT OF SOAP GOES A LONG WAY ) this allows you to tinker with the wrap, a bit longer to get it straight ( without it sticking too bad ), once you get it centered, it is pretty easy after that.
    Soapy water makes it easy to remove any wrinkles as well! ( no different than tinting a window on a auto ) But the wraps are sticky, and Soap will help a bit, once it is on and dries out, you ain't getting it back off! I thought it would be cool, but ended up ditching the idea, later as edges started to peel, from placing and removing it from case, I ended up spending over an hour trying to remove residue! It looked cool, but I will NEVER do it again!
    Down note:
    Once removed, if you don't get ALL the residue off, bird will get VERY dirty, fast, as every little speck of dirt/dust will stick to the residue, it was a nightmare for me! But some of those wraps are cool as hell! Up to you! Also they are pre-cut, and fit well over the bends and curves! Hope this helps, and good luck!
    J Dot
    :cool:
    dirkclod likes this.
  3. sandman259
    sandman259 Guest
    Yes it does thanks...think I'll stick with the naked bird...lol
  4. J Dot
    Sarasota, FL. USA!
    A+
    Personally,
    That was my start, but over the years, my favorite decoration on ALL my birds, are carbon fiber looking arm, battery, and FAA stickers, all matching colors. ( actually FAA stickers are just reg vinyl, as the carbon fiber ones are too thick, to cut to the size I need ( very small )),
    To me it is the most pleasing, plus there are a TON of colors!
    Here is an example of one of my birds.
    ( this is black carbon fiber stickers )
    The chameleon carbon fiber is really cool, but pics do no justice for them, but in person they change a lot of colors.
    Again just my input, but there are tons of things you can do to give your bird that little touch of yourself!
    Take care, and good luck to you!
    Fly safe!
    J Dot
    :cool:
  5. sandman259
    sandman259 Guest
    My original plan was to just replace my arm stickers but the factory ones suck and always peel up. Are those aftermarket ones on the arms? Where did you get them?
  6. J Dot
    Sarasota, FL. USA!
  7. sandman259
    sandman259 Guest
    Are they a lot better then the factory ones? Stick better?
  8. J Dot
    Sarasota, FL. USA!
    They are thicker, and more sticky, any sticker is prone to peeling, but mine seem to be doing well, so far, I did order extra sets just n case, but have not used them yet, lol.
    I think they are much higher quality than stock, and much more color choices.
    J Dot
  9. Flipsonic
    San Francisco Bay Area
    Not that hard to put on. It took about half hour since I wanted to be careful not to screw it up. This particular skin did not fit perfect. I had to make some minor adjustments with an exacto knife. If you are careful, it's easy to push out the bubbles to the edge. This one is made out of vinyl. I carefully used a hair dryer to smooth out the bubbles. I plan to change it later when I'm sick of this look.
    [​IMG]
    #9 Flipsonic, Aug 26, 2016
    geejdee likes this.
  10. sandman259
    sandman259 Guest
    That does look pretty awesome...I might pull the trigger sometime for fun....
  11. HueJorgan
    Bish Vegas - Co. Durham UK
    I make vinyl graphics and signs in the uk
    Any sticker should have the surface cleaned before applying we use methylated spirit on a lint free cloth or tissue (bog roll if you will)
    Soapy water does help a novice but it can have an effect on the adhesive making it weaker
    Thicker vinyl usually means it's cheap we use avery vinyl with a lifespan of 7 years out doors and it's only 60 microns thick
    I really must finish that p3 template I was drawing in vector so I can decorate my baby lol
  12. sjp0eqt
    What camera is that on your Phantom ?
  13. Phantomic
    Used a hair dryer too for applying these skins, also used a needle to remove the bubbles.
    [​IMG]
    [​IMG]
  14. Fifty7
  15. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Their easy if you just take your time . Have used several different co.'s but use this one now DecalGirl | Custom Cases + Removable Skins For Your Electronics!
    Now what's cool here is after you go through and find the skins you will see where you can use your picture and make your own design
    They are not high and they are quick to get it done . If nothing else just check it out and make a skin .You don't have to buy it .
    J Dot likes this.
  16. J Dot
    Sarasota, FL. USA!
    Stock fc200 camera with a rotorpixel gimbal, was a gift from @dirkclod
    Yeah, that guy in the post up above me, lol. ( Thanks buddy )!
    J Dot
    :cool:
  17. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Well you fixed it after I crashed it .
Similar Threads - Skins (are hard Forum Date
Standard Are skins a bad idea? Phantom 3 Help Jan 6, 2018
Skins Phantom 4 Pro Discussion Oct 8, 2017
Skins Standard Aug 7, 2017
Skins General Discussion Jun 17, 2017
Skins for your Phantom General Discussion Apr 25, 2017
