Simultaneous Video recording and continuous picturing
Discussion in 'Phantom 2 Vision + Discussion' started by lfaitas, Jan 26, 2015.
  1. lfaitas
    Halo everyone!
    i was wandering if it was possible on the DJI Phantom 2 vision+ v3.0 to have Simultaneous Video recording and continuous picturing?
    I know it is possible with the gopro camera.
    If it a software issue would an update on the Vision app fix this?
    What do you usually do? i would hate to have to go through the same path twice just to record once and then take pictures again the second time!
    Thanks everyone!
  2. BlackTracer
    Winter Park, FL USA
    Well as far as we know, the vision app and camera don't do simultaneous video and stills. I sometimes capture HD screenshots of the video in post-production, but that won't work if it is raw format you are seeking.
  3. lfaitas
    shame they didnt mention that when i had to choose between the vision and the vision+ ..
    if i knew i would go for the vision with the gopro camera which has this feature...
  4. LostAngel
    El Campo, TX
    if you are just wanting one particular scene in a video, it is very easy to do. Run video, pause the scene you like, hit the windows start button, goto the run box, type "snippingtool" and crop the scene you want.
    Otherwise, research this
    http://ffmpeg.zeranoe.com/builds/
  5. lfaitas
    i know that but it would not be of the same quality .. also not possible to take multiple photos during flight...
    i know the work around but just wandering if it was at all possible.. many times users find simple solutions!
  6. GSSP
    go full screen in HD with Video, just hit print screen at anytime, paste into pic editor like paint or whatever
  7. Fplvert
    Southern Idaho USA
    :D
    If you want a Phantom with a GoPro most people go with the non-vision Phantom 2.
  8. lfaitas
    i know .. its too late now!
    Cant fit the vision+ gimble to a gopro can i?
  9. Fplvert
    Southern Idaho USA
  10. LostAngel
    El Campo, TX
    That is my next major expenditure, after I get back from Vancouver next month. I bought the GoPro4 Silver for the zipline's and I should get about $1000 back from IRS (greedy bastards...) so, I think that's where it will go. Waiting for the H4-3D gimbal to come out next month or so.
  11. ilovecoffee
    Just to confirm on this, the hardware for the camera doesn't allow simultaneous capture/video from my experimentation trying to keep the photo button enabled when recording video. I just get "Camera Busy" errors. I think it's due to the limited write speed.
  12. lfaitas
    excellent option but very expensive!
    i read the vision+ camera is pretty much the same quality as the gopro hero 3 .. dont know about the hero 4 ..
    I insist it is a software thing and can surely be an option in a future firmware update of camera and iphone app..
  13. lfaitas
    even for the vision+ v3.0 camera ? i thought it was not that bad compared to the gopro hero 3?
  14. TuT
    TuT
    Sydney, Australia
    I have the Vision+ and was quite disappointed with the camera, especially the harsh video quality. I upgraded to a GoPro 4 Silver and the quality is yards ahead, especially low-light performance. I am using the H3-3D Gimbal with my Hero 4.
  15. bond101
  16. lfaitas
    I didnt see an gimbals for gopro in that video link you sent..
    Is the expensive Quickrelease P2V+ the only solution? .. 239€ plus the camera!!
  17. kenargo
    I can confirm that the camera (or camera firmware) cannot capture photos and video at the same time. I can confirm this because I am building an app and wanted to remove the limit so I allowed photo taking while recording video and each time you take a photo the video is stopped.
    I cannot confirm if this is a limitation in the camera or the command protocol between the cell phone/tablet and Phantom but when using the SDK the behavior is the 2 are not allowed at the same time.
  18. CadKing
    You might want to check out the conversation about changing out the vision plus gimble and camera for the Zenmuse and Gopro (linked below). Seems like they have just about got the problem solved (if you aren't running an iphone like I am). Still it's very intriguing to be able to swap out the one camera for the other and keep almost all the function of the vision plus. Especially worth looking at if you've got a damaged camera.
    http://www.rcgroups.com/forums/showpost.php?p=30390846&postcount=252
Similar Threads - Simultaneous Video recording Forum Date
GoPro 4 - Simultaneous Video and Stills Zenmuse H3-3D/H4-3D GoPro Gimbal Nov 27, 2014
question on gopro simultaneous pictures and video FPV (First Person View) Sep 2, 2014
Simultaneous Video out while continious picturing Phantom 2 Discussion Aug 1, 2014
GoPro Simultaneous Pics and Video Phantom 2 Discussion Mar 19, 2014
P3P : Can i use 2 CF props and 2 plastic dji props simultaneously Pro/Adv Discussion May 22, 2017
