Simulator POV
Anyone know if you can change the simulator's camera view?
What I mean is; in the simulator you can see everything from the operator's POV. Is it possible to change that to the view from the P3P's camera just as we view it in the field?
If so how do I do this?
it would be well cool if you could have a area you are going to fly in
Guess I was hoping for the simulator to be more of a Google Earth type view. I'd like to have bearings from the FPV as well as the map display. And also try and visualize the shot a little more. Very easy to fly outside of that green square you start on.
Doesn't make a lot of sense for it to be available on android and not ios when they specifically claim the app to be primarily coded for ios devices. The fact that my Samsung Tab Pro doesn't fit the RC but my iPad Air 2 does should argue for my case.
The Simulator on Android sucks, there is a small square of simulated grass then everything else is just a gray screen, but you can select camera view of nothing or visual mode of not much. IOS blows android away other than no camera view
