I thought I would share my DIY Monitor mount I made to attach my FPV Monitor to my Phantom Radio. Fortunately the hobby stores near me didn't have any mounting brackets in stock so I came up with this concept. I'm glad I did because it is totally configurable and requires not tools to change or adjust. First off, YOU NEED TO HAVE A MONITOR THAT HAS A TRIPOD THREAD ON THE BOTTOM. If you are like me, you have a GoPro and probably quite a few mounts. The 2 pieces you might not have are the GoPro tripod adapter and a 1/4-20 x 1/2" long set screw. Other then that, you need One Flat Adhesive mount, One Quick Release Buckle and a 3 Way Pivot Arm. You will need to cut off the end ear (the one with the nut) on the 3 way pivot arm portion that you choose to attach to the tripod adapter. I put some Loc-Tite on the 1/4-20 screw thread that goes into the tripod adapter.
Everything can be disassembled for easy transport and all you are left with on your radio is the Flat Adesive Mount.
