Shudder vibration
Discussion in 'Phantom 2 Discussion' started by Sledge, Sep 4, 2014.
  1. Sledge
    All of the sudden my P2 and, more notably, the gimbal are showing a visible vibration.....not huge, but noticeable when hovering in front of me.....never had vibrations before...any ideas?
  2. IrishSights
    Bangor, Northern Ireland, UK
    Check the screws that hold the gimbal to the shell. Part of my regular maintenance. Check props are balanced and matched to the motors. A crash can upset this even a tip over can cause a prop to be un-matched and out of balance.
    Sent from Samsung S4 via Tapatalk
  3. Sledge
    The gimbal is tight, compass dance completed, changed out one motor that was acting up.....bit still have the high frequency shuttle/vibration.
    What might I try next? Should I do an advanced calibration?
  4. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Yes. Do an advanced IMU cal and then closely inspect your props for and wobble, distortion while hovering. You haven't changed the gains by any chance have you?
  5. Sledge
    Thanks, I will try that. I did check prop balance as well, and they all checked out.
    I haven't changed gains , other than the gimbal tilt gain a long time ago.
  6. Sledge
    So I have balanced my props, tried other props, done an advanced calibration, compass calibration, checked the H3-3D to make sure it's secure......and still getting this vibration shudder......I am at wits send.
    Any suggestions?
  7. ussvertigo
    South Georgia
    I'm interested in this thread. My early videos when just hovering would be rock solid when looking closely at the edge of the picture. Now visualy it has a hard to notice shutter, and the edge of the video when hovering has very slight shutter back and forth (2d gimbal). I had replaced one esc unit after led lights quit. New props and imu cal no change. I had changed the gain for the yaw trying to slow rotation down for video, but changing back didn't help. I suspect imu or esc. By the way, I bought some counterfeit props that really made the problem worse, and other negative performance issues. I thought getting the 3d gimbal would eliminate this, but is big gamble, prefer spending on fpv gear.
  8. Spetter
    Netherlands
    Do you use the original white dampers for the gimbal? I used the black once once. They were to soft and made P2 shaking like hell.
    Other test could be removing the gimbal total, thereafter put the gimbal back under but not connected to check for any balance issues.
    Keep us updated on this one!
  9. ianwood
    ianwood Taco Wrangler
    Lost Angeles
    Your gimbal and P2 are in a feedback loop. If you ever saw the movie Gravity, you'll know that when one thing moves anything attached to it is going to move as well. Something has changed in the frequency in which your P2 or gimbal correct their balance. It could be the rubber balls or it could be a gain settings.
  10. krsdj1
    Long Island New York
    Can you recommend a good balancer from amazon or ebay,possibly a name of the balancer ? Thanks
  11. Sledge
    That makes sense, but I don't think I changed anything (same dampeners, etc.) when the vibration arose.
    I have balanced my props with the dubro balancer and used 2 different sets just to make sure that wasn't it.
    The only gains I have ever changed is the X1 tilt gain. (to the best of my recollection)
    Here is a video showing the vibration: http://youtu.be/ei-spF8iYK0
  12. Spetter
    Netherlands
    I recommend to use harder dampers for the gimbal.
    I'm almost sure that fixes the problem.
  13. paulajayne
    Bocking - England
    That looks like the bird is vibrating as the landing gear is having a boogie. Try it with the GoPro unmounted.
  14. ianwood
    Lost Angeles
    Yep. That's a feedback loop. I would focus on the gimbal mounting. Don't fly for long like that.
  15. Sledge
    Thanks - I will give it a look tomorrow. Appreciate you're input!
Similar Threads - Shudder vibration Forum Date
P2 H3-2D vibration "shuddering" issue Phantom 2 Discussion Apr 23, 2014
P4P shuddered when flown using Autopilot Phantom 4 Pro Discussion Mar 20, 2017
shuddering in flight ? Standard Jan 17, 2016
Camera shudder P3A General Discussion Jan 15, 2016
P2 shuddering Phantom 2 Help Sep 12, 2014
