Show us your home made parts
Discussion in 'General Discussion' started by flick5848, Jan 31, 2016.
  1. flick5848
    Lancashire, UK
    It's not currently flying weather here so I decided get creative in the workshop and make my own gimbal protector. It was hand machined and not CNC as can be seen by few rough edges.
    gez and rulppa like this.
  2. J.James
    Upstate NY
    Wow that looks real good considering you were turning your dials by hand esp on the rounded contours. I cant get a good round contour by hand on a milling machine to save my life. Its like trying to make a perfect circle on an etch and sketch.
    But yours looks as good as any of the ones for sale look as far as the machining goes.
  3. flick5848
    Lancashire, UK
    Thanks.
    I used a rotary table and a 4 jaw chuck to get the rounded edge. half hour to set up for 2 minutes machining but Like you said, its fairly impossible with the dials.
  4. J.James
    Upstate NY
    ohhhhh ok now a rotary table that makes things a lot easier. lol I can even mill a nice full circle with a rotary table by hand. .
  5. Noble 1
    Oregon
    Excellent work! Nice handmade product. I'd really like to know how practical having all those tools would be. Someone was trying to talk me in to buying a 3D printer for CNC and plastics... I'd primly use it 10 times... Then what?
  6. J.James
    Upstate NY
    I guess how practical they are depends on what you happen to do with them. I have happened to over the years acquired a small cnc milling machine. a small tool makers lathe, cnc plasma cutting table that I built. along with lots of other metal working equipment. such as sheers, bending break. and my most recent acquisition which Is some thing I did not think I would find a whole lot of things to use it for in till after I got it was my 3d printer. Which turns out I'm finding all sorts of uses for it more then all my other stuff. esp with it right here inside my house at my computer desk makes it convenient to use any time I need to make some thing in plastic.
    It even saved my butt last week after I ran in to some real pain in the butt fittings on the heater hose connections on my old ladys car that even tho they are called quick disconnect fittings they by no means are quick or even easy to get off and needed a speshial tool to release the clips inside the fitting to even be able to get the busted ones off of the car. I had to special order a tool for them that was a real pos tool that was made out of some sort of pot metal like matchbox car bodys are made of and it busted the first time trying to use it and didnt even get the fittings off. So there was an alternative tool that's made just for gm heater hose fittings that instead was made out of nylon so I wait another week for one of them to arrive in the mail being none of the local auto parts stores had any on hand. Well I get the dang thing and it was well made and a lot stronger then the pot metal one. BUT for some reason its about 1/8 inch bigger diameter then it needs to be to even work and fit inside the fitting to release the clips. Ughhhhhh What should of been 1/2 hour job to get my old ladys car running again and also have heat was starting to turn in to an almost 2 week nightmare. Then it dawned on me that all I had to do was print out a new tool like the one that was the wrong size and just get the dimensions right and It saved me big time even tho I had to try 3 different times. One was still to big the next was just a hair to small. But the 3rd one was the charm and worked perfect. I had the fittings off in less then a minute.
Similar Threads - Show home made Forum Date
After flying my p3a. It got to about100 ft and then returned to home. It was showing disconnected. Pro/Adv Discussion Sep 30, 2016
Home Point not showing on map Pro/Adv Discussion Jun 12, 2016
Home button not shown in DJI GO app Pro/Adv Discussion Mar 23, 2016
Dynamic Home Point always showing yellow? Phantom 2 Vision + Discussion Feb 21, 2015
Home Lock shows strange behaviour Phantom 2 Discussion Aug 20, 2014
